Mountain_man
Ok I have been having timing problems with my 350. I set the timing at 0 in closed loop with est wire unplugged. Shut down the engine and reconnect the plug (wire right next to brake booster) and restart the engine. The code will not clear. I've pulled the fuse and everything. I recheck the timing with the wire plugged in and it still shows same 0 timing! I've verified through this site that it's the correct wire to unplug yet the light keeps coming on with same code. I've also got a serious knock in the engine with the timing set this way. What else could I be looking at?
I'm getting code 42 btw.
I also just changed to the 3wire o2 sensor and it's working correctly. Has got to be a problem with computer seeing the advance from distributor once connected. Would really explain everything but I'm going crazy here.
I've done no real changes since this started happening however new cap/rotor/wires/plugs and I've verified the wire placement to be correct. I hope someone can help with this cause it's not drivable. Thanks
Josh
Josh
