91 suburban WINALDL problems.
y5mgisi
1 ton status
Portland Oregon
So, for some reason my winaldl will not read the computer on my buddies 91 4x4 350/4l80e 3/4ton stock truck. It reads my 90 just fine but wont read his. Any insite?:dunno:
Make sure in the configuration that you have the correct ECM checked. I'm pretty sure that it doesn't use the "7747" ECM.
Winaldl will not work on the '91 w/ the 4l80e. His Suburban most likely has the 14167060 PCM that runs at a higher baud rate than 1990. Try TunerPro http://tunerpro.net/ He probably will also need the $85 mask that he can download from Moats.
Got it! THanks! So with tuner pro(i already have it downloaded) is there anything i need to do to it to make it read his comp? settings wise? Do i need to download the $85 mask for it just to read his computer?
You do need to download the correct files. I don't think you need the $85 (that is for editing) to read, but you do need another file - I can not remember what type it is (maybe an xdf files???). It is on Moates.
datamaster is a great and easy program. Download/install/open/go to record data/either record or monitor and bang you have data. 20 free reads with the program trial so you can see if you like it.
