91 tbi 5.7 why cant i use a gear drive
84CUCV
3/4 ton status
NJ for now
i was told with the computer fi truck. i cant use this. so how can i use it? rework the computer or somethings?? any ideas?:confused:
thanks
IIRC it makes noise or vibration and the knock sensor thinks it's knocking, retards the timing, gets all screwed up.
-- A
You can use a gear drive timing if you get a chip with the knock sensor deleted from the programing.
If you are building a high performance TBI engine you should delete the knock sensor anyhow.
no, the computer used it to adjust timing, if you got ride of it, it would probably ping alot.
I think he is talking about a gear drive for the timing.
If you do some reading about them they are not recommended by most drag racers due to harmonics problems transfering from the crank to the cam. There is no performance gain from a gear drive timing set.
If you just want the whine then that is up to you, but you will need to get a new prom for the ECM.
GM used a BUNCH of different knock sensors, and while I couldn't find it, I know I saw threads on thirdgen discussing using gear drives. Some people were not having problems.
Besides using different knock sensors, GM also "deadened" some applications by mounting them on brackets off the engine.
As mentioned, you aren't going to see gains with timing gears, and even the stock nylon geared timing sets typically last as long as the engine, a solid metal double row/roller chain is probably at least twice as durable. (with as many nylon toothed setupsas are out there, if timing chains were a real problem, it would be the only reason GM engines died)
The noise and or harmonics of a gear drive is what the knock sensor will pick up and retard your timing. You can simply unplug the knock sensor wire and this will no longer happen. You do not need to have a new chip made without the knock sensor since nothing will happen anyways with the wire disconnected. It's a bad thing to do to delete the knock sensor since it actually helps you in case of engine ping going up hills or on heavy acceration.
At risk of going off topic, how do we know that the tune of all knock sensors is exactly what the gear drives give off?
I know the GM test given (at least in some GM manuals) is to smack the block with a hammer and watch the scanner for knock detection. That's a whole lot different than a gear drive setup making whining noises. (which understandably translates to harmonics of course)
Not saying one way or the other, I think there are too many variables out there to make a blanket statement on this is all. There just doesn't seem to be concrete info out there.
Still not a proponent of gear drives for street use, but that's not my call on someone elses rig. :)
