Hey Guys,
I'm a long time member on CK5, but never ventured into this forum.
I have a 91 V2500 burb with a new GM crate motor 15k ago.
Motor is stock, except the following:
TBI Spacer
Salad Bowl Intake Mod
Injector Spacer
Adjustable Fuel Pressure Regulator - Currently at 15, but normally at 13.
Edelbrock TBI Manifold
Flowtech Headers
3 wire O2 to fix o2 code after header install
Long story short, my truck runs hot. 200-210 cruising, up to 235+ towing up grades, etc. Last motor ran hot too.
Full story at: http://coloradok5.com/forums/showthread.php?t=298869&highlight=overhaul+cooling
Has always heated up quickly, even stock. Cooling upgrades are as follows:
Ac Delco Water Pump
High Flow 195˚ tstat
AC Delco HD Fan Clutch
Champion Radiator, CC716, 3 Row All Aluminum
50/50 coolant.
Water Wetter Additive
Factory Oil Cooler in front of rad, and same cooler on passenger side for trans
Replaced the ECM a couple years ago to fix a weird intermittent stumbling issue. ACDELCO 88999179 Engine Control Module (ECM Computer)
So, recently it was suggested i unplug my o2, and by chance, see if it runs better on the "default" program. Nothing really happened.
So, here i am. What can i do to further troubleshoot this? Is their a diagnostic ohm reading i can take on the o2 wire to make sure its registering like it should at the computer?
Any suggestions on attacking this from a tuning standpoint? I'm a big fan of simplicity on this truck, and just want it to cool properly. With the cooling upgrades I have, this thing should be bulletproof.
Not excited to get into any custom tuning, but figure its worth a shot. Or, at least i should do some data logging, or setup a wideband o2 to see what is going on. All stemming from the idea that running lean would make it run hot.
Any ideas?
I'm willing to try just about anything, as this has been going on for years, and is keeping me from being able to rely on my truck to tow when i need it. I've literally replaced EVERYTHING, and have no idea how to proceed forward.
Thanks guys!
TBI Spacer
Injector Spacer
Flowtech Headers
Ac Delco Water Pump
50/50 coolant.
Any ideas?
Thanks guys!
