91 to 73 K5 Nose Swap
Coontail
Massachusetts
I know this has been discussed a lot already but I have a question
The fender - door gap gets wider as you look down so i found that removing the radiator support mount it almost lines up perfect
It's seems I now have to cut the rad support mount perchs in half to compensate for the width of the mount
Is this a bad idea or am i missing something? Everyone else says all they had to do was swap the wiper linkage and they were done on the 85s and 87s. Any insight is appreciated
Yeahhhhhh idk how they are different but they are... I think I have both sets at the shop. I'll try and dig them out tomorrow
Ok, I think I might just get a couple washers and find a couple thin poly bushings somewhere. That way if I need to I can adjust the height
