Leper
As some of you know, I am being forced to sell my stuff to make up for some poor financial decisions a few years ago. This listing is for my Black 1992 2wd Dodge Cummins turbo diesel dually. It has the inline 6 and an automatic transmission. It is an extended cab 8' bed LE model. There are about 140K miles on the clock. The modifications include: Mag hytec double deep pan, aux trans cooler,bed mounted, with fan; 3 piece ATS manifold, 16 cm turbo housing, 3200 RPM spring installed, fuel pin cut heavy, blower relay mod is installed, Gauges include: exh temp, tach, boost,and 2 trans temps, one sender in the pan, and one to be put in the output line, lots of other little things have been done.
The truck comes with a bunch of parts that I have yet to install including: spare headlight switch, spare ignition switch, fuel pump, starter rebuild kit, vac. pump rebuild kit, new condenser and dryer for the A/C( it works but it leaks out freon in a couple of months) Brite box for the headlights, turbo timer, fuel pressure sending unit and gauge, extra small mirrors, new tailgate and bedrail diamond plate covers, other things that slip my mind right now
The truck is in great mechanical condition. The only issue that someone may have with it is that it has some minor body damage on the dr side of the bed and tailgate. I was rearended, and although the Ruenel bumper took most of the damage, the tailgate was hit and there is a small wrinkle on the left side of the bed and the fender has a crack in it. I have a complete other bed (with tailgate)that comes with the truck if the buyer wants it and can take it.
I am asking $7500 obo for the truck at this time. Feel free to make a serious offer if you think my price is out of line. I am a motivated seller, but I am not going to consider a 2500 offer. I have had this truck about a year and have put thousands of dollars into it to make it as reliable as possible. This was the truck I was going to pull my Blazer from Texas to Moab with.
I will try and have some pictures up here in a couple of days. Vehicle is located North of Dallas.
