basketcatch19
Registered Member
trying to figure out the tow rating on my 92 truck the door sticker says gawr front 3925 rear 3750 i believe this number is for loaded wait on the axle. As it sits right now 350 tbi nv4500 14bolt semi float extra cab wheel base is at 141.5 inches 373 gears. The trailer ways in about 2200 lbs bumper pull and rig is unknown at this time i would guess around 5500 or so k5 but all tubed and not to much sheet metal stock frame. single axle trailer brakes. I have towed with this before and did fine going up hill at about 25-30. Really i want to know if i am pushing my luck or not i am hopeing to have a cc again next season but this is what i have for now also the farthest i would be going would be about 2.5 hours. Total wieght would be around 13,000 give or take so if some one knows what the gvwr would be with the bigger axle in it then stock. that would help thanks.
