michael0584
Not k5 related but there is such a wealth of knowledge here I thought I'd ask here first.
I have a 92 mitsubishi galant that starts cutting out after driving for awhile. Does not happen on short distances, but will randomly happen on trips over about 30miles. The engine just starts cutting out rpms go down, but will come back up, car bucks as rpms go up and down, car will idle fine but power cuts in and out above idle. I can put the car in neutral and cut the engine off, start it back up and sometimes this will fix the problem temporarily. but, the further you drive the more it occurs. I drove the car to work (60mi round trip) tues, wed, and today. Today was the only day it messed up this week.
The Long History of the car
My grandpas sisters hurband had this car, I think he bought it new. Always took good care of it and had it serviced regularly. He died in 04. He had stopped driving it shortly before he died because it didn't run right after timing belt was replaced. My grandpa's sister gave the car to me in 05 and we found the timing belt was 1 tooth off. Installed another new timing belt and it now ran fine except it smoked and had a bad oil leak. Installed new valve seals and oil pan gasket to fix smoking and oil leak. Took it for a test drive and heard a noise and then a rubbing noise from timing cover. pulled it off and the balance shaft had seized and popped the belt for the balance shaft and then rubbed the timing belt. Installed a balance shaft eliminator kit and another new timing belt and all was good. After driving the car a long distance I noticed this cutting out problem. I replaced fuel filter, air filter, tps, and throttle body (used), also checked the ecm. Also it has intermittent high idle problems, Replaced the IAC with several used ones and still has the idle issue. I got tired of working on it in 05 and parked it in the barn. I would start it up and drive it about once a yr. Got it out last week and cleaned iy up, changed the oil, checked all fluids and realized the trans would not shift, replaced the tcm and that fixed the trans. I'm thinking it may be the ignition module on the distributor or the fuel pump, but not sure.
