93 Corvette LT1 6-spd
@Fastereddie what ever happened to the YJ you were working on?
I still have it. It’s just very low on the list. It is going to require a whole lot of time and money being a ground up build from scratch. I just wanted to get it as a roller so its portable and will most likely be a retirement project haha.
The Dewitt in my Camaro dropped the temps quite a bit if there's enough airflow.
Yeah I believe it. The stock fan ON temp on this thing is 228. I let it idle up to that temp and the first fan came on. Temp started dropping right away. It went down to about 202. Then I turned the a/c on and the second fan kicked on. Dropped down to about 190 before I shut it off. This has the stock 180 thermostat.
Eprom tuning. I have alot of Megasquirt experience on tunerstudio. And some new genV stuff on Hp tuners. Now looks like i’ll be
learning about obd1 tuning. I just ordered some stuff from Moates and downloaded Tunerpro Rt. First thing I want to do is lower the fan on temp.
