notsosanestan
Registered Member
truck has a 2 inch suspension lift and 3 inch body
i just put new upper and lower balljoints. tie rod ends. cv shafts, pitman arm, idler arm, steering stablizer and more but gas tank started to seep gas a little and i have no time
the truck has 112000 miles on it and i am the second owner
when i got the truck i replaced the rear with a posi one and all the brake lines.
Front fenders i replaced and got painted, truck starts up everytime when there is gas in it. i need this to go asap dont have the room and i dont wanna scrap it.
has rust in the rockers, bottom of doors and back left bottom quater panel. and left cab mount. would be great for parts as the engine and trans are perfect.
but with a lil bit of work it will drive
thanks
thanks
