94' 5.7 full size blazer plz help
Izmrpickel
Registered Member
Hey everyone, my name is Matt. Sadly I'm at a complete loss with my blazer. So a week ago she started dying at an idle, no hesitation it would just die. When it would do this it wouldn't start back up until the engine was cooled off a bit, then she would fire back up, and no issues. This led me to look at the ignition control module, changed it and had no problem, fired right up and drove home. Then i had no start the next day. Inspecting why I found I have no spark at cyl 1, and at the coil, figured with 185k+ miles I'd replace the coil, cap, and rotor. Still no spark, wondering if the ignition control module was bad again took it in to have it tested and the parts store replaced it anyway, still no spark, and it was installing the ignition control module for a 2nd time I noticed I have no fuel as well. So I went to town on trouble shooting. The knock sensor is at 3.5k ohms, 1.3 ohms @ both injectors, 12v @ tack wire, 12v @ ICM from coil, 682 ohms @ pickups/ distributor, 12v @ temperature sensor (don't know what resistance I should have at 39°f), .64v - 4.9v @ tps, new iac, new coil, new cap+rotor, rotor dose spin, fuel relay is functioning, and fuel pump is running. I have no obd1 codes, it just repeats 12. All grounds I have tested are good, however I may have missed some. all fuses look and test just fine, and the engine turns over strong, when she was running I had no problems. I need some further ideas on what to look for and test because I'm beginning to think somehow my ECM is bad, and idk how to do the relearn procedures, and don't really want to. Any ideas, known faults, or even just throwing an idea back and forth. I'm effectively the only mechanic I know, and I'm needing some help. You guys got anything after reading all that? Thanks for the time.
Forgot to mention, I do have 12v at injectors, and have inspected the knock wire and there is no open or grounding at the header.
