'94 S10 Blazer blinker lever/switch
pismorat
California
I need to get at the switch that controls the blinkers and high beams. The high's don't work and the wipers also come on when I hit the blinkers (sometimes). How do I get that thing out? Any help would be greatly appreciated.
If your talking about the lever itself, you push in, twist then pull the lever out
High beam switch is toward the bottom of the column. It has a rod that runs down from the switch and moves the switch at the bottom. As Muddytazz said you can remove the lever, but the wiper switch must be removed after removing the wheel, turn signal, then you can get to the switch for the wipers. My Astro has the same issue, I am just too lazy to tear into it to replace the wiper switch, and it seems to be worst when it is cold so I don't worry about it too much.
