Kenny78
1994 5.7 TBI
My truck barely runs and is getting worse. If it were carbed, I would say that the float bowl is running out. It was running alright at idle b ut right after you take off it sputters and dies. Now it will barely start, if at all. In an effort to save money and correctly diagnose the problem.
I got a fuel pressure tester and adapter(what a pain to install) and here comes the question: When the fuel pump primes, should it go to 12-13psi?
While cranking and after prime the fuel pressure never moves. If I press the bleed off valve some fuel will come out eventually, but nothing like I expected
Does this tell me that my pump is not building any pressure and needs replacing?
P.S. I checked to make triple sure that the pump was priming, and i found something else.
When I turn the key on and listen for the prime, it runs continuously
