chulisohombre
Having a issue guys. Seems like the engine is not advancing on throttle. Replaced map and tps. Knock sensor was broken so replaced that too. Any more than quarter throttle it wants to die open loop it runs awesome if I restart the engine. About a minute later starts to die again when it hits closed loop again. I'm going to get a aldl cable next and see what that says. But anything else I can look at. Egr tests good and fixed vacuum leaks I had. Injector pulse good and new fuel pump and tank few months ago as well as filter. Any help I'd appreciate it.
