94 Z28 coupe
Bent77
I am CK5
Nunya
Nothing fancy, but needs some loving. Actually been trying to sell it, and have only been offered $3500
Probably keep it at that price
Good:
LT1 in proper working condition. 4L60e,
Power everything. Radio needs replaced. 155 speedo, factory oil cooler
48,000 miles
Bad:
Sits a lot, needs tires, AC needs repairs, and I have an “ABS In Op” and “Air Bag” light on. Both pretty common for this body. Working with the help of @ZooMad75 to track those down
FC647F62-59E9-4381-AE05-184021D26057.jpeg1984D1A8-F641-42ED-A543-69CA4371752F.jpegADF14686-1190-48CA-84E2-0F7C9AF07D75.jpeg
If I keep it, think I’ll do a tune, cold air kit and a 750cfm throttle body. That was a good recipe for the other 94 I had. Made 287hp and 378lb/ft at the wheels. Ran high 13s here with cast iron manifolds
Have you had the distributor problems common to the LT1?
I drove a few of those with a few mild mods from the factory. Fun Cars! Use gears to slow down because they are hard on brakes. In the 3 I drove I had one transmission go out. Other than that very dependable, sucked in the snow, part of why I drove several others didn't like them in the snow and not easy to get in and out of alot! Even with the issues price doesn't seem bad to me but I haven't looked at there value in a few years.
Might have to tap your brain.
Are you using the mass air?
