95 1 ton 14 bolt
chevyk2500hd
Lafayette, Indiana
I have a 14 bolt from a 95 1 ton van that has been laying around i dont need anymore. This 14 bolt has the large 13in drums. I am pretty sure it has 3.73s and the carrier is open. There is some surface rust on the axle shafts since it was taken apart outside for a period of time. The ring also has some surface rust that can be easily taken off with steel wool. It could be easily cleaned up and used as is. Couple pictures are below.
$75
i have a friend that lives up that way if he can pick it up i will take it off your hands.
Dude, If you weren't sooooo far away id pick it up in a heart beat, as of now my axle smiles at me:D , yea just like that---if you would ship i would be interested. gimme a quote
right on. i may have to run down to jjlaughner's place to pick up some parts, and could just swing by his place on the way to or from your place. that is a hell of a drive, but a hell of a price too. lemme know.
Well the wms to wms is 69.875 roughly. The spring perches are like 2.5 inches wide. I am not 100% sure on the drums but I would say non press on drums because I didn't even know they made press on drums on 14 bolts
Perches are wider on 1 tons. If you are putting this on a 3/4 or 1/2 ton you'll have to cut these off and weld on new ones.
with the '73-91s this is true, however, nobody seems to know with the 88-98 trucks (which is what i'm building, if you couldnt tell by my sig) the 95 Van may very well be the same.
any word on that spring pad to spring pad (center pin to center pin) measurement? really needing an axle, and cant find one up this way. :dunno:
