95- 350 stock part swap
CHEVYDADDY
BARDSTOWN KY
I found a 95 350 block but valves in heads need to be cleaned. I do have 85 350 heads with eldelbrock intake and 4 - barrel carb.
So 1) Can i put my disturber and 4 barrel carb on a stock intake on the 95 gm intake?
2)Can i put my good 85 heads that match my redbrick carb and intake on the 95 350 block?
3) I'm wanting to go serpentine belt and have all the pulls but the ALT. Either heads will work with the brackets on the 95 block right.
1.)Distributors will swap between motors/intakes. Carb will not bolt onto the stock 95 intake. I don't know if anyone makes an adapter for TBI (I'm assuming you have TBI) to carb.
2.)The heads from the 85 will bolt onto the 95 block. You may have to use the intake from the 85, as the 95's might have the 2 center bolts angled differntly.
3.)All four heads should be drilled/tapped the same on the ends for accesories.
