95 k-2500 running problems
Cornfield creations
Jasper, Indiana
Our 95 k-2500 with a 454 quit running, figured out that the fuel pump went out. We replaced the fuel pump with a GM, and the ECM1 fuse under the hood. Now it will run, but it won't idle. You can hold it steady at a higher RPM but as soon as you let off the gas it'll die. I am at a loss at the moment. Any help is greatly appreciated!!!!
