95 s10 blazer oil cooler lines
mudhog
THEGAME
portland oregon
ok i am beyond sick of this. i have a 95 s10 blazer as my daily driver. and for the fifth time replacing these things in as many years i am sick and tired of replacing them. is there a way to just bypass the damn things?
yes
where the lines go into the oil cooler take the lines out and remove them totally, remove the fittings and install 3/8 pipe plugs and do away with them totally. no it wont hurt the motor
one more thing if the "0" rings seals are leaking at the block this is a great time to replace them. advance auto parts sells the seal kit for the oil filter housing it's about 10 bucks. you can pull the housing down to make it a little easier.
Helped my friend replace those cooler lines at his shop a week ago--had to take out the drivers side motor mount bolt and raise the engine up before they could be snaked out from between the engine and crossmember!...after we got it all back together with 2 new lines and the block O-rings,it still weeped oil out of where the O-rings go to the block...:doah:...so the customer has to come back soon to try again...
I suggested doing what I did to my 6.2,just make a loop out of 3/8" copper tubing and bridge the two cooler ports together...he didn't like that idea though...funny thing is,on my truck,neither of the cooler lines had any oil come out of them after I cut them off,even if I blew air thru them...I bet nothing ever made it into the cooler!...so "deleting" them didn't harm anything,and I dont think the cooler in the radiator does all that much anyway..
I know of many one ton dump trucks at cranberry bogs that no longer have the oil cooler hooked up,if anything was to blow up it'd be those trucks,they get abused badly!...guy who does the fleet maintenence showed me a cooler he cut out from a 6.2 radiator he replaced,it looked like someone stuffed gunpowder inside it and lit it up,it was all puffed up!..
I bet those cheesy OEM oil cooler lines made GM a lot of sales of new trucks and engines...mine had the crimped areas rot completely off on the side facing the ground you cant see,the top side looked perfect too..surprised the rubber didn't blow off the fittings...
