I have never really messed with TBI much. I have a '95 Chevy truck at work that has a 305 in it. Still obd1 so I can't hook to it with my scanner but I get no flash codes. It died the other week and I ended up finding the ignition module had failed in the distributor. Last year I resealed the intake manifold for a coolant leak and replaced the entire distributor and coil. The new module failed so I swapped the old one back in and it ran great. They brought it back to me yesterday and it is hard to start and runs crappy. You have to give it throttle to get it to run and it idles at like 400-500 rpm and if I crack the throttle too fast with the air cleaner off it just dies. Any direction to go? It doesn't have a ton of miles maybe 130K but mostly hours on it but usually a great truck.
