96 Tahoe, Rear disc help...
blazeonchevy
san antonio tx
It has been a while since I last got on here, but I figured I could see if anyone here could help me out.
I bought a 96 Tahoe a few weeks ago, and someone down the line installed a rear disc conversion on it. So now I have the problem of needing to find new calipers and pads for it, but I have no idea what kind of part number to be looking for. No one around seems to have any idea. It has the emergency brake still intact, and the only kit I can find like it is this one.
http://www.paddockparts.com/Paddock...akes&mscssid=8E395180CABD4B62836B9A7FA4B9FCAB
Part #: A1263
That site has no info that I can find about what kind of calipers these are.
If anyone has any advice it would be great.
Thanks guys.
Have you checked out TSM for their brake setups? How about a good picture of what you have?
How does the e-brake operate on yours? That sometimes helps figure out what they are from, as does rotor thickness and diameter.
any cast numbers on the calipers? i had an issue with a part(i cant remember what)but i went to napa and they found the numbers on it, typed them in and found the right part i needed.
Figured it out
Thanks for the replies guys. I took one of the calipers to a couple of parts stores and they figured out a part #, but could not figure out the application. I had to wait until today when a local auto parts store opened. I know the owner and he helped me out. Turns out they are from a 1981 Oldsmobile Toronado. :doah:So it is running again. Now I just have to start working on the blazer again.
