97 1/2 ton front diff seal
thezentree
3/4 ton status
NC
my 97 yukon is leaking gear lube out of the front driverside diff seal. its also starting to tick somewhere in the front end with wheelspeed, so im guessing a bearing went bad and busted the seal.
anyway, how much should i expect to pay for this? its not something im comfortable doing, and im going on a road trip in the next couple of weeks. i called the only stealership around that does quality work (still pricey), and they quoted me $270 total for the seal.
help? /forums/images/graemlins/crazy.gif
sounds about right, its a sealed unit and real easy to replace yourself, eventually it will lock up on you so better get it fixed. They got us over a barrel with those, who hires these engineers?
Do both driver and pass side i messed up on that only replaced my driver side its VERY Easy the whole front diff can be dropped in about 1 hour mabey less w/ air tools but get both seals fixed as now my pass side is leaking so sometime soon ill have to drop it agin.
