DEMON44
Low-Tech Redneck
Sorry for the cross post, but I just noticed this injection forum, so this is my first time in here
OK have '97 CC dually with Vortec 454 and NV4500 stick. Need help to diagnose. Been having an engine vibration since I got it.
first plug wires were rotted out and arcing. so changed them out. helped some. Now still have engine vibration. and just got CEL, said bank #2 running lean. So shot manifolds with temp gun. driver side all got to 300* quick and even.....
but passengerside
ambient 32*
#2 virtually no temp increase ~43* maybe just from compressing air
#4 slight temp increase 67*
#6 got to 200*
#8 virtually no temp increase.
.........so why? all injectors on 2 bank bad? is there separate drivers for each bank? got one bad? I did run an injector cleaner cycle after changing the plug wires........not a bottle in the fuel tank kind but a real hook up to the test port on the fuel rail, disable the pump, and close off return line. run off a pressurized bottle and regulator. no real change.
any ideas? I'm not sharp with gas engines.
thanks guys.
but passengerside
ambient 32*
#6 got to 200*
thanks guys.
