carolinafan4life63
what is the sensor on top of the fuel pump on a 98 suburban?? not the electrical connector for the power supply but this looks like a sensor ..has a electrical plug on it and pushes down into a small hole in the top part of the fuel pump!! the reason i am asking is the replacement pump did not have the hole to plug the sensor into , so i left it plugged in but loose on top of the tank!!..also on the old pump where the lines hook up the middle tube was non functioning...on the new pump the middle tube was open as if for a vent hose or something....i left it alone also!! just wondering why the difference in the two pumps.......i installed the new pump and am having no problems , codes or ill effects , thanks
