carolinafan4life63
ok guys , got one for ya!! a buddy of minine brought his 98 burb over last night....said in the mornings it will crank over good but will not start ....untill he hooks jumper cables to it ......then it will start and run......but after about 45 mins to an hour of driving it will start cutting out and eventually die on him!!!he can let it sit for about 10 mins and it will start and run for another 8-10 miles befoere doing the same thing!!! i just went out to try and start it this morning and it turns over great all the power acc. work and all of the lights on the dash come on when the key is switched on........although i seem to recall seeing all the icons on the dash except the service engine soon light!!! took the cap off of the fuel rail and got just a tiny little spurt when i depressed the valve............so , should i be looking at a fuel pump, ignition module , clogged fuel filter or what direction should i go..it has 200,000 miles on it, thanks
