Thru good samaritan stupidity, i broke the front L CV shaft and the mount for the front pumpkin. The CV shaft is easy. The front pumpkin is another story.
Can the center section be unbolted and removed for repair without removing the entire suspension? ( i know the CV shafts have to be removed)
If so, can the upper mount be welded back in place and hold like original?
If not, can the case be swapped out with another without having to set-up gearing engagement like shims or adjusters again?
Im trying to NOT spend 1000.00 bucks for repairing my friends truck.
That 1000.00 was earmarked for the Blazer transmission job that was needed.
PLEASE HELP!!!!!!!!!
