GMCJason
Hey all, I've got a problem with my A/C in my Jimmy. First, it's not cold but that maybe coolant charge problem. The bigger issue is that the A/C compressor engages and disengages about every 3 seconds. When it gets warmed up it's enough to cause a noticeable surge when idling in gear.
The other part of the puzzle is that a couple years ago the in-cab controls smoked a bit. There was obviously a problem but I didn't think too much of it because all the functions seemed to work. Later on it did seem that the A/C was always on as long as the unit wasn't off...for instance the vent air seemed to cold just to be vent air.
Any ideas? I'd like to get the compressor and idle surge problem taken care of but not sure where to begin. Could the surging be related to a malfunction in the controls, like it thinks the A/C is on? Even if it did would it have that much of an effect on idle speed?
Thanks for any input.
Could've been from the blower switch or the A/C switch mounted to the heater control? May have to take out the control and visually inspect for burn marks or possible wire problem at the harness connector side.
