A/C condensor
NEK5
3/4 ton status
Ipswich MA
So I finally figured out the problem with the ac in my DD. The bottom of condenser is leaking out. Anyone know the best/cheapest place to pick up a good replacement? It's for a 2004 scion xa.
Thanks in advance!
Salvage yard would be cheapest...they dont usually fail all that often,so I bet you can find a good one for cheep ..new,I would say Rock Auto,they seem hard to beat as far as prices..
I would go to the junkyard, piece together a Chevy and leave the Scion there :dunno:
But seriously, I put a used condensor in my Pontiac like 3 years ago and it's still freezing cold in there. Usually they go bad from a rock hit or something rubbing against them and can't really wear out. But if you go with a used one - FLUSH IT.
EDIT: I guess if the fittings weren't mounted solidly to something, the constant vibration could work harden the lines and split them. So you should make sure the factory mounts are all there and maybe add something if there isn't any.
