Bigb55
Installed an A/C delete kit on my '74. Uses a fiberglass box to replace the old evap box and seal up the heater core area. My truck had a DIY box installed prior to my ownership. It worked, but had multiple gaps and sucked engine heat instead of from the cowl vent.
I Maintained my relay and blower resistor so I still have a multiple speed fan and air recirculation mode is always on. Now to buy some wire loom and organize the wiring better.
Overall it's a nicely built box and very thick.
1973 to 90 GM & GMC Truck AC Delete Cover for C/K Series, Suburban, Jimmy, Blazer and more
This is a 1973 to 1990 GM and GMC Truck AC Delete Cover that fits all C/K Series, Blazer, Surburban, and other GM & GMC Trucks. it is designed to remove your original AC system and at the same time maintain the used of the heater and defrost.
www.acdelete.com
