A/C delete question
What do you need to know? Pull it all out, cut the shoe box off the firewall and cut some sheetmetal to cover the huge hole up. I used some silicone and self tapping sheetmetal screws to put it in place.
It's easy enough to do.
i was just wondering what you put to block the hole that is now in the radiator. i was thinking about a tube plug. and also what size plug needs to be put in place of the hose for the intake manifold.
By removing that box on the firewall, do you lose all blower capabilities? If I do an A/C delete, but still wanna use heat in the winter, do I need to leave that box there?
