The A/C in the k3500 could use a little help and I thought the root of my problem was that it seemed low on R134 (the compressor cycles on and off pretty often) so before I took it in to an a/c shop I decided to give one of those cans a shot...
I fired up the truck and turned the A/C to full blast (like it said) and then connected the hose to the low pressure port...
It starts at 20psi and builds to 45psi... once it hits 45psi the compressor kicks on and it drops back down to 20psi and builds back up, etc.
The can says 45psi is at the high side of where it should be... but does that mean it should be there all the time? When it kicks on and drops to 20psi should I fill it or do they mean if it never reaches the "full" zone (like 30-45psi) that you need to fill it until it can build pressure to be in that zone?
Wow I hope that made sense...
Basically everything is physically working on the A/C system but on hot days it never really gets cold (colder than the outside temp but not nearly as cold as the C2500's A/C system gets to and they're literally identical)...
