A/C pressures
mo'gas
Registered Member
Flagstaff, AZ
What should the A/C pressures be on a 89 K5 Blazer R-12? What conditions? ie: engine speed, outside air temp, vent temp etc?
Thanks,
Dave
i think the normal pressure is around 2.5million psi:D but really, dont the recharging kit come with the gauge that has the green range, and lets you know when its full?
Do you have a set of refrigeration guages? If so the guages will have the R-12 temp scale to compare your temps to.
Example. Generally the center vent at idle will blow 32 degree air.
Do you actually have a source for R-12 if you need to top it off?
no i dont have a set of gauges, but i worked at napa and saw them all the time, they come with most of the re charge kits. im 99% sure you can get R-12 at napa but its a lot more then the R-134a.
you have to have an epa license to buy it.
Okay, Just my opinion here but if the system is not performing as you expect it should, Then I recommend that you retro fit it to operate on 134-A as it is available at all parts stores and even Walmart. No EPA license is necessary to purchase it either. If you are not familiar with refrigeration systems, then I think that for your safety and the reduced chance of "messing something up" you should let a shop help you.
The shop that does my AC work found a source of R-12 that is not too unreasonable. I would not have converted my truck if it had been available to them at that time. Every vehicle that I have been in that has had a low dollar type of conversion does not cool nearly as well on 134-A.
Agreed with the less effective cooling issue. Just thinking long term and availability as well as the lack of the EPA license or shop to access the R-12
Anyhow,
I have a gauge set.
I have more than enough R-12 to last me, my buddies and all our kids a long time.
I know that the general rule is high side pressure should be approximately the same as 2.5 times the ambient air temperature. I was just wondering if someone had their factory manual handy and could look up the specs for me.
Dave
BTW,
You do not need a license to posess R-12 or to use it in a non commercial capacity.
It is only needed to purchase or commercially use it. I have a MACS license, but have been out of the industry for some time.
You need no license to purchase R-134 in a non commercial capacity either. However 134 is trickier to use than 12 and can easily get overcharged resulting in poor performance.
