A/C pump replacement
snowdriver
oregon
image.png my a/c pump died a few years ago,thinking I need to get this fixed and came across this on eBay,is there something else other than what is here that needs to be replaced as well,any thoughts or ideas or experiance ?
If you have the serpentine setup from a 1996 to 1998, this mounts the the compressor on the driver side, that compressor will bolt right in. I am not sure the drier will work with the Square body setup. It might with with new hose.This will require new hose end to connect to our original setups. It will need an adapter on the manifold. This serpentine setup will allow the use of a factory 250 amp alternator. I am in the process of converting mine now.
