So if I can get a clutch rebuild kit somewhere and then put a belt on it that should be my plan of attack?
Well, its a cr*pshoot.
You could put a clutch kit on, start it running, and then find out the compressor knocks under load or seizes up after a few minutes.
You might consider just getting a new compressor with clutch installed.
I just checked, and it looks like your truck uses the R4 pancake type. They work well, but are prone to suddenly seizing.
A new clutch assembly will run between $100 and $130, and an entire rebuilt compressor with clutch will be about $165.
I think you would be better off paying the extra $35 or so.
You will not get any power to the compressor unless the gas pressure is above a certain pressure. There is a low pressure switch, usually mounted on the accumulator, that tank like thing next to the firewall.
Its a round switch looking a lot like a big oil pressure switch with two wires coming out.
You can unplug the switch and jumper across the wires to see if you get power.
