I just did the r134 change over to my '84 k5. Rent manifold gauges and vacuum pump at Autozone. 300 to rent then they refund the entire 300 when you return them. Evacuate the system, hold a 30hg vaccum for forty five minutes with the pump off to insure you don't have a leak, then turn the vaccum pump back on and run it at least 2 more hoursburn off any moisture in the system. Find a pressure table for ambient temps and charge.
My manual says 48 oz of r-12. I put in about 35 oz of r134. with readings at the gauges of 29 low side and 250 high side on a 100 degree day.
I am going to try to tune it a little this weekend. On 100 degree days in humid Houston, texas, it barely will keep me comfortable. I knew I probably could add more freon, but wanted to take it easy to make sure I did'nt blow anything. I replaced, hoses, compressor, o-rings, seals, accumulator and orifice tube. It all cost 350 bucks for everything.
Read up on it and learn how to do it yourself, that way you will not be spending a fortune on your AC. Face it, these trucks are old, and you will be in there often.
Also, work on your vents under the dash and seal them good.
The is a place on the web called ackits they have a forum that will help you out.
