1996-2000 GMT400 trucks equipped with the "Vortec" SBCs used the Harrison HT6 compressor. The compressor is located on the driver side (same side as my 1985 factory R4 compressor). If you utilize the Vortec setup make sure to get an "upgraded design" HT6 compressor. The original design has problems leaking between the front and rear halves. There's also a Sanden compressor that is a drop in replacement for the HT6, I believe it is well regarded. The other reason I like the Vortec setup is alternator selection. The newer "AD" alternators (the AD230 and AD244) used on LS engines bolt on to the bracket with no modification. The factory CS130D isn't too bad either.
