Just my $.02 worth .....
I agree with all who said that swapping anything for a few MPG's is an exspensive way to go for minimal gain. That being said I am one of those in-line six wierdo's who swapped out motors to run an in-line motor .
A 292 is a fine engine but fuel economy is not what it is known for. I have a 292 going in my daily driver Blazer that has LPG pistons , decked block , shaved head , marine cam grind , T.B.I. , intake and all the standard goody's but it WAS NOT cheap by any means . My intention was to gain serious bottom end torque not economy.
I am also installing a 6BT in my off-road Blazer and once again it ain't cheap ! If I was doing these motor swaps for better mileage than I would be waisting my time and serious coin expecting a return in better economy.
When it is all said and done I have built strong BBC's for far less money than I have got in my 292 - after market parts just ain't cheap for them......
Good luck in what ever you choose to do !
Tom
Tom
!). He has had the pickup on the road for a couple of years now and he has probably put about 10-20,000 miles on it, so it hasn't been too long. The transmission was pretty new when the conversion took place, and was behind a 305 with 200k. Aside from the torque converter, I think that he put a new governor in it. Otherwise, it is a stock transmission.
It has 93k original miles on it. Very frustrating. Maybe the distributor is bad but not sure. I have MSD Off Road and a K&N filter. I had a scan done a few weeks ago and all it showed was the voltage going up and down on the O2 sensor. The sensor tested good. Looks recent. Something is making it react to whatever is causing the problem. Got new 3" Magnaflow exhaust. TBI O rings??? Leaking injectors. Got to fix it. Thanks and Happy New year!
H.
