Got the engine running. But it gets hot fast, just over 210 degrees & then I shut it off. But the engine, radiator & hoses just don't feel that hot. The electric fans don't even come on unless I over ride them & they are set at its lowest setting of 160 degrees
Could there be an air pocked in the motor, not allowing the water to fully circulate thru out the motor?
When I disconnected the EST wire to time it the engine just did not want to run, and had a difficult time restarting it & keeping it running.
Do I disconnect the EST wire before starting it or during idling?
I removed the spark plugs and they were all black, kind of an oily black, I couldn't wipe it off. They all look the same.
I used NKGR V-power UR5 spark plugs, Should I be using a different plug?
Engine is a late model factory roller 4 blt main block. 383 rotating assembly, scat crank & 6" rods, Probe forged pistons. World S/R Torquer heads.Cam is a Comp Cam # CCA-08-302-8, Lift .480/.480, Duration 264/274, Lobe Separation 112.
Thanks, Ed
Thanks, Ed
