a good pic from this weekend
GEORGIA GABE
Conyers, ga
So we went to mountainside off road park in Sandrock Al this past weekend. this was a climb called bad egg... Ill say it was a little bit hairy, and no I didnt make it.
gabe
youtube: mountainsideorp the trial is called bad egg. Only one person has made it so far, on 37in trepadors competition sticky compounds. Everyone else has been denied or rolled. There is a video of a green jeep that had it if he had let off the gas, lets just say he went for a ride.
gabe
Georgiagabe, Is your rig parked in Conyers by chance? I saw one the other day close to our shop, looked just like yours.
Did you air-down?
I was thinking the same i see people running beadlocks and there is no tire buldge, i run 7 to 8 in mine with no bead locks have not lost a bead yet? day is coming om sure.
Where you there when the jeep rolled
It really depends on where I will be wheeling and what kind of terrain as to what psi I run. the lowest I run them is 4psi and the highest is 11psi. But when you are vertical with the inside edge of one tire holding you from rolling, knowing you wont loose a bead is nice.
In the pic below you can see how much tire wrap/Sidewall flex I get on Launch
looks like a blast! it seems like every time i see pics of ur rig, theres less and less sheet-metal on there haha
