As says the title… 1988 TBI 350- manual transmission means it got the AIR /smog pump stuff here in CA.
I drove the truck HARD earlier this week. Rocky trails/sandhills… in and out of low range… revved the motor good quite a bit. Things were running fine… we stopped for a beer.
When starting the engine 30min later -rough idle. Drove away in 4-low and left the play area. Get to open road and shift into 2high- immediately I notice how bad the power loss is- I’m working the throttle and slipping the clutch just to pull away in first gear on flat ground… then check engine light came on and ran even rougher. Then the light went away and it ran a little better again.
The Lights on the dash cluster went out… (there may be something up with the combo switch) lights came back on -repeated a couple times.
I made it home.
Visual inspection and everything looks in place. pulled codes
43-knock sensor
44 - lean condition
I made it home.
43-knock sensor
44 - lean condition
