A little more lift...
jms
Author
I might need a little more lift in the rear to prevent a 'prerunner' stance...
I just changed the front from worn TC 3" EZ to new TC 3" HD springs.
The rear is a 2.5" ORD shackle flip and a 1" ORD ZeroRate. I also hope to have a new rear tube bumper come BlazerBash, with tire carrier and gas can.
I could...
1. wait until the front settles a bit; maybe not carry so much stuff... ($0... I like that...)
2. take the ZeroRate out, add an add-a-leaf ($50 + new U-bolts) gain ~1"
3. just add the add-a-leaf ($50 + new U-bolts), gain 1.5" to 2"
4. add air springs ($250 or so...)
5. replace the 2.5" flip with a 4" ($180 or so and a PITA due to the tank...)
I'd run everything and see how it sits. $0 is a good way to go. If its sitting butt low in a bit, just deal until th esprings settle, still butt low then go with an add a leaf.
Hmm. Hadn't thought about that possibility. Wouldn't a longer shackle upset my pinion angle even more?
I'll get back to you for details about those airbags when I'm back from New York...
I wouldn't mind a little more spring rate in the back to go with the slightly stiffer springs up front, and I had thought about air helper springs before...
The idea stems back from driving Rocker Knocker in Pritchett, and the thought that you just could inflate the driver's rear to be a little less 'offcamber' in this obstacle was somewhat appealing...
Interesting idea. I've wondered how air bags would work in offroad situations. Is this a very common thing to do?
