Well, when it came to the front rockwell boyce wanted way to much for a generic front axle so after some shopping I found a guy down in Tucson AZ that does govt surplus and he pulled a front rockwell from a Deuce and a half that was in a fire. Got it for $750.
The stock tie rod was bent, it was okay because the stock ones are pretty weak and I wanted to replace it anyways
a butt load of suit was on this thing, spent way too much time cleaning it
drum brakes removed, these things are crazy heavy, got some money for them from the scrap yard to pay for other crap. I ground off the steering arm from where it bolts to the knuckle since I am going with full hydro steering. I just reused the 4 bolt hole part.
flanges, hub, spindle and axles removed. Notice I have removed a few studs drom the knuckle, that's because I had to replace them to flip the front hubs.
Okay, this has been by far the most disappointing thing during the build, I take apart the front and they are bendix axles, not u-joint style. Every source I read (including 4-wheeler, Petersen's 4 wheel and offroad, jp magazine, and Boyce equipment) said that if the tag on the axle says "rockwell" and not "timkin" then they will be u-joint style... Um I learned first hand that isn't true. Oh well, I will run them til they break and replace them with some chromo's.
mocked up the suspension making sure to take into account where the pinion brake will be so it won't rub on the leaf spring.
another myth in a lot of articles is that you have to machine the rotor to flip it in to make it as narrow as the rear. Not true. You can replace the studs with these countersink bolts after drilling out the holes on the spindle for the counter sinks. You can also just grind down the back of the wheel studs because that's what rubs. You don't have to cut apart the housing and shorten the long side to narrow it.
Also if you are throwing this into a chevy, flipping the hubs will fit a lot better under the engine than narrowing the axle housing, plus it puts the wheel surface to wheel surface at 69 1/2"... 1/2" wider than stock.
it's close but doesn't rub, plus I torque'd those bolts down like a mother and put thread locker on them so they don't back out.
