A noisey 10 bolt.
The Griff
High drag, low speed
Fieldon Illinois
The Blazer has developed a couple new noises. For a while now the rear 10 bolt has squeaked when I backed up, but now if I turn to the left or right, it makes these loud popping noises from whichever side would be going faster. Also when going forward I get a consistent clunking. About a year and a half ago I changed the fluid in it and it doesn't leak, so I know it has fluid.
The best way to describe the sound is like taking an taking an aluminum can and twisting it until it rips.
Is is full float time?
Sounds like you have some bearing and/or differential issues. For what you'd spend in parts and time to fix the problem, it's not really worth it. Take it as an opportunity to upgrade, or if bigger tires/hard wheeling isn't in your future, just go pick up another 10 bolt.
