A Rausch Creek run is needed
FOR MUD
Clayton Del
Were looking at August 28th - 30th
We will be running the usual blues, blacks and reds.
I know I'll be camping at the park.
As of now, I Know for sure I'll be there and Jay (twoslow)
So get your junk fixed an come on.
There is a chance the gumbo mudders will be going in the museum, I bought some re centered H1s a week ago and found some 42 inch iroks that I need to go pick up. Only thing I'm missing is the money to get them with :(
I went all out.....I put some unbent springs on the back and half a new u-joint...Might even check the oil too.
sounding like me with the exception of checking the oil. I put motor mounts on and built a roof, mounted my winch and wired up a wireless remote. thats been about it. I did pick up a 2 tank into 1 Y for my propane, just need to cut the hose and make up the ends.
Have fun guys, my truck is too beat to go through wheeling again this year I think.
Injectors (When they ever get here) glow plugs, harmonic balancer, lift pump, oil pressure switch, replace exhaust system, replace front tires, rewire trailer connector.....Plus a fuel pump on the work truck....Plus replacing connector and checking wiring on the trailer.....Plus cut the grass (3 hrs worth)....Plus what ever else comes up.
But fear not, I have two days to get it all done.:D
You definitely can't use one for towing, while not making it up a steep climb, it will blow up and take out a school bus load of nuns.
That happened to me last time on that big hill on RT-81 right before the turn off to Rausch........Never knew a piston could fly that far and decapitate six burning nuns at one shot.
