A smog question, again.
cuervo
Runn'n down a dream!
Sweet Home Alabama!
Hey all,
I purchased a 91 suburban 3/4 ton that was first sold in AZ and then registered in CA. I was wondering if had a lot of smog gear on it. I can see that it doesn't have the air injection pipes in the exhaust manifolds and not pump. But, I thought the AZ laws were the same as CA laws.
Thanks again,
Core support tag will show you, if present. There is NOTHING in regards to mog that is going to noticeably affect power, given it's working correctly, if that's where you are heading. :)
If you NEED to make sure it's all correct, the core support sticker is the way to go, I think autozone or someone is actually putting those up on the web for you to check.
