a6 compressor + brackets for 6.2
I actually have an A6 compressor, but not the 6.2 bracketry. I have the small block brackets. I am going serp drive and I think will be using a sanden compressor. The A6 is less than a year old, but it only has about 20 minutes of usage. I threw the belt twice due to misalignment, then never got around to fixing the belt. I left the compressor attached so that it could stay filled with the refrigerant and not get any internal corrosion.
Do you still have those D44 gears? I have to check on shipping this big beast to hawaii, but may be interested in a trade for those gears if you still have them.
Yeah, I have them, I'm up for a trade. One of the flat rate boxes is 8.5x11x5.5, Might be able to squeeze it in there. Post offices seem pretty reasonable about accepting bulging flat rate boxes.
I have the front and rear compressor brackets. But none of the engine side interested?
PM me if you are.
I don't know what the brackets are like, so what do you mean by the front & rear, but not the engine side? are the brackets a whole lot of pieces?
I will try to get some pics of an assembled piece and of what I have. Yes there are several pieces.
