Nutro
Another dumb question. The 88 has a 5.5" lift on it with aftermarket 2.5" leaf packs front and rear and lift blocks rear and some home made shackles in front to lift it more.
I bought front HD shackles from ORD and I am going to remove the rear 3" blocks to make it 2.5 again.
I don't have any crazy tools or a lift so I am going to do this by myself in the street. No biggie. So...
On the front, do I loosen the U bolts on the front, loosen the shackles at the rear-most position, slide the jack and a large block of wood under the spring and remove the shackle, drop the jack a little then install new ORD HD shackle and slowly jack the spring back up and slide bolts in, put back on the ground then tighten U-bolts and shackles with the vehicle weight loaded and I'm done?
Rear same concept? Jack diff up, loosen U-bolts, pull blocks and taper shims, jack it back into place and tighten U-bolts and done?
This is assuming the shocks are removed front and rear.
