The Pumpkinator
do us all a favor get the 3/4 ton spring thing out of your head.
someone sold you on a line of bullits option from factory 3 leaf front and 5 leaf rear all 1/2 ton stuff. just your replacement springs have more arch as new and prob been arched more for lift to level the blazer as thay sit a$$ low.
true 3/4 ton and 1 ton rear springs are 56" long and start around 8 leaf - 10 leaf per pack.
and 4" lift gets you 4" lift like it said in the ad you read.
and if you later want to go to 56" leafs for more flex in the rear all you need to do is swap the left and right brackets for the flip then bolt in the springs. cheeters trick on the flip swap.
and dont forget the flip kit req you to drop the fuel tank on the blazer to get the brackets bolted on.
some pinion angle correction will be required more than likly. but no sure fire set fix. each vehicle requires there own setup. so you have to bolt in the kit and see what you get.
and if you do the front springs get new shackle hanger bushings with hd shackles its worth it. and i love my greasable bolts for much smother ride.
longer brake lines will be required for the 4" kit for best results. ord has quality line kits.
if you plan on street time and good road handling get the sway bar disconect kit so you can keep the bar and then play offroad with it unhooked. but most of us remove the sway bar and never look back
you got any plans for steering correction ? simple easy raised arm or drop pitman arm is best. i prefer the drop pitman arm for the steering box. faster to swap out and resale value is higher than raised arm for axle end.
and plan on few days to do this job and plan on few problems. hope you have backup dd vehicle.
hope this helps you.
Thanks, simply said and to the point
. Sad but true with the PO giving me the best line in bull****, but never had buyer's remorse from taking this truck home. I am also aware that this will take a long weekend to get this all together (I had to swap in a new axle to replace the rear 10 bolt that I scattered...then only to find out that one of my rear leafs was cracked in two; hence the new springs I put in there, and I also had the tank dropped numerous times because of the damn fuel pump and rotten O rings on the sender leaking
) and I do have a secondary vehicle that I can drive.So I already see a detailed list of what I need, but what about shocks? Monroes or Gabriels? Are the ones supplied from ORD decent as far as dampening and shock travel?
