abs brakes ?
NEK5
3/4 ton status
Ipswich MA
ok when i was lookin around in my engine compartment while we were working on the steerin i noticed something about my brakes..it appears to be that the plugs are not plugged in...are they supposed to be like that?
how can i find out if there is an issue with the abs system??? do i need it hooked up?
No you don't need it hooked up. Unless you like the abs brakes then you can just leave it unplugged. If you plug it in and the abs light comes on then you have a problem.
Abs
Have the axles been swapped? If so, no ABS. ABS can be trouble on the trail, but it can save your **S on the street. The axles that have ABS will have some sort of sensor attached.
Plug it in. To test - go to a level dirt road/fire service road. Get to 10 to 20 MPH and slam on the brakes. Hang on and get ready. The brake pedel should pulse and there should be no lockup. The truck should stop straight. If you feel the truck begin to yaw, get off the brakes and get it under control. Don't risk a roll.
You will probably find the PO hacked something and the ABS is dead. You know, bad pump, or something.
i actually just got back from the mechanic i bought my truck off of and he told me that he unplugged the abs because it was going to be used for his trail rig and he also heard they sucked
