The clutch on my AC Compressor on the k3500 started squeaking a couple weeks back... I've been shooting it with some WD-40 about once a week and it's been quiet but I know I'm just masking a problem...
So is there a way to figure out if it's the clutch... maybe a bearing... heck maybe low pressure in the system so it's not getting lubed (although it still engages and I'm not 100% sure but I think on the newer trucks if the pressure in the system is low it won't engage the clutch to protect the compressor so I kind of ruled out low pressure)...
Anyways... what's a good way to diagnose this? Oh and btw I know it's not the belt... I have a new one on and it still has good tension and you can just tell it's coming from the clutch... I put a nozzle on the WD-40 and put a tiny little spritz between the plates on the clutch and it stopped squeaking without getting any on the belt.
Ok thanks for suggestions!
